Perform this procedure to configure Multi-area SPB layer 3 redistribution in the home area.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select MultiArea.
  3. Select the L3 Redist Home tab.
  4. Select Insert.
  5. In the VrfId field, type the Virtual Router Forwarding ID.
  6. In the Type field, select the layer 3 redistribution type.
  7. Optional: In the RoutePolicy field, type the name of the redistribution policy.
  8. Select Enable.
  9. In the Apply field, select apply.
  10. Select Insert.
L3 Redist Home Field Descriptions
Use the data in the following table to use the L3 Redist Home tab.
Name Description
VrfId
Specifies the Virtual Router Forwarding ID.
Type
Specifies the layer 3 redistribution type. The options are:
  • ip-ucast - IPv4 unicast
  • ip-mcast - IPv4 multicast
  • ipv6-ucast - IPv6 unicast
RoutePolicy
Associates a route policy to a specific layer 3 redistribution entry in the home area.
Enable
Enables layer 3 redistribution in the home area. The default value is disabled.
Apply
Applies the Multi-area SPB layer 3 redistribution filters in the home area. The default value is noAction.
