Configure ACE IP source address entries to have the filter look for specific source IP addresses.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select IP.
  8. Select the Source Address tab.
  9. Select Insert.
  10. Specify the operation type.
  11. In the IPAddr box, enter the source IP address.
  12. Select Insert.
Source Address field descriptions
Use the data in the following table to use the Source Address tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
IPAddr
Specifies the source IP address.
OperMask
Specifies the mask value for the source IP address.
