Display individual DHCP-relay statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View DHCP-relay statistics:
Switch:1>enable Switch:1#show interfaces gigabitethernet statistics dhcp-relay ================================================================================ Port Stats Dhcp ================================================================================ PORT_NUM VRF NAME NUMREQUEST NUMREPLY -------------------------------------------------------------------------------- 1/12 GlobalRouter 0 2 1/13 GlobalRouter 3 2 2/3 GlobalRouter 0 2 --------------------------------------------------------------------------------
Use the data in the following table to use the show interfaces GigabitEthernet statistics dhcp-relay command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF instance by VRF name. |
vrfids WORD<0-255> |
Specifies the ID of the VRF. |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (1/1). Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
