Use Trace SPBM to Diagnose Problems
Use the following procedure to display trace information for SPBM IS-IS. In the case of IS-IS, this procedure also provides information related to the flags set.
Use the trace level 119 <0–4> command to trace IS-IS module information, including CLI, instrumentation, show config and platform dependent code. The IS-IS module ID is 119.
Use the trace level 125 <0–4> command to trace SPBM module information, including CLI, instrumentation, show config and platform dependent code. The SPBM module ID is 125.
Use the trace spbm isis level command to trace platform independent code, IS-IS protocol, IS-IS hello, IS-IS adjacency, LSP processing, and IS-IS computation.
![Caution](images/caution.png)
Caution
Risk of traffic loss
Using the trace tool inappropriately can cause CPU lockup conditions, loss of access to the device, loss of protocols, and service degradation.
Switch:1>enable Switch:1#configure terminal Switch:1(config)# clear trace Switch:1(config)# trace spbm isis level 3 Switch:1(config)# trace shutdown Switch:1(config)# show trace spbm isis ================================================================================ SPBM ISIS Tracing Info ================================================================================ Status : Enabled Level : VERY_TERSE Flag Info : Switch:1(config)#trace level 125 3 Switch:1(config)#trace level 119 3 Switch:1(config)# save trace Switch:1(config)# trace grep error Switch:1(config)#trace grep 00-1A-4B-8A-FB-6B
The following table defines parameters for the trace command.
Variable |
Value |
cfm level [<0-4>] |
Starts the trace by specifying the level.
filter |
Configure a filter trace for a file or module. |
flags |
Configure trace flags for IS-IS or OSPF. |
grep [WORD<0-128>] |
Searches trace results for a specific string value, for example, the word error. Performs a comparison of trace messages. |
level [<Module_ID>] [<0-4>] |
Starts the trace by specifying the module ID and level.
route-map |
Enables or disables the trace route-map. The values are on and off. |
screen {disable|enable} |
Enables the display of trace output to the screen. |
shutdown |
Stops the trace operation. |
spbm isis level [<0-4>] |
The default is 1, very terse. |
The following table defines parameters for the save trace command.
Variable |
Value |
file WORD<1–99> |
Specifies the file name in one of the following formats:
/mnt/intflash is the internal flash of the CPU. /mnt/extflash is the external flash of the CPU. |
