Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to display the OVSDB protocol support for VXLAN Gateway configuration.
show ovsdb config
SWITCH:1>show ovsdb config
Ovsdb Config Info
Status - Enabled
Certificate - Installed
Private Key - Installed
Replication Peer NLS-IP - 192.0.2.3
Replication Local NLS-IP - 192.0.2.2
Ovsdb Controller Config Info
ID Protocol IP Port
1 ssl 192.0.2.10 6640
