Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
    enable
    configure terminal
  2. Configure the PIM virtual neighbor:
    ip pim virtual-neighbor <A.B.C.D> <A.B.C.D>
Switch:1(config)#ip pim virtual-neighbor 192.0.2.0 198.51.100.0
Variable definitions
Use the definitions in the following table to use the ip pim virtual-neighbor command.
Variable
Value
{A.B.C.D} {A.B.C.D}
The first IP address indicates the IP address of the selected interface. The second IP address indicates the IP address of the neighbor.
