View fan tray information to see manufacturing information about the fans.
![Note](images/note.png)
This procedure does not apply to XA1400 Series.
- On the Device Physical View, select the Device.
- Select Chassis.
- Select the Fan Tray Info tab.
Fan Tray Info field descriptions
Use the data in the following table to use the Fan Tray Info tab.
Name |
Description |
TrayId Note: Exception: Only
supported on VSP 8600
Series.
Specifies the fan tray ID. |
Description |
Shows a description of the fan tray. |
SerialNumber Note: Exception: Only
Series.
Shows the serial number for the fan tray. |
PartNumber Note: Exception: Only
Series.
Shows the part number for the fan tray. |
FlowType |
Specifies whether the air flow is front-to-back or back-to-front. |
