Display the VTEP Next Hop
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to display information about the remote VTEP.
- Select VTEP.
- Select the Next Hop tab.
Next Hop field descriptions
Use the data in the following table to use the Next Hop tab.
Name |
Description |
VtepId |
Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
Ip |
Specifies an IP address that uniquely identifies this remote VTEP tunnel. |
IfIndex |
Specifies the interface index of the next hop to reach the remote VTEP. |
Vid |
Specifies the VLAN ID of the next hop to reach remote VTEP. |
