Perform this procedure to configure a remote IS-IS manual area.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the Manual Area tab.
  4. Select Insert.
  5. In the AreaAddr field, type the Area Address.
  6. Select Insert.
Manual Area Field Descriptions
Use the data in the following table to use the Manual Area tab.
Name
Description
AreaAddr
Specifies the remote IS-IS manual-area in the range of 1 to 13 bytes.
