This procedure only applies to XA1400 Series.
Use the following procedure to display the CPU COSQ statistics and counters.
show io cpu-cosq-counters
Switch:1# show io cpu-cosq-counters ======== PORT 1 COSQ STATS ======== bash-4.3# tc -s filter show dev veth101 ingress | grep 'match\|Sent' match 00008902/0000ffff at -4 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match 00110000/00ff0000 at 8 match 00000043/0000ffff at 20 Sent 7965012 bytes 23991 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match 00110000/00ff0000 at 8 match 00000044/0000ffff at 20 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00008103/0000ffff at -4 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match e0000005/ffffffff at 16 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match e0000006/ffffffff at 16 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match e0000009/ffffffff at 16 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000100/0000ffff at -16 match 81000100/ffffffff at -12 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000100/0000ffff at -16 match 81000101/ffffffff at -12 Sent 1819852 bytes 39562 pkts (dropped 0, overlimits 0) match 00000800/0000ffff at -4 match e0000012/ffffffff at 16 match 00700000/00ff0000 at 8 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000806/0000ffff at -4 Sent 87129474 bytes 1894119 pkts (dropped 0, overlimits 387255) match 00000800/0000ffff at -4 match 00110000/00ff0000 at 8 match ffffffff/ffffffff at 16 Sent 0 bytes 0 pkts (dropped 0, overlimits 0) match 00000900/0000ffff at -16 match 2b000005/ffffffff at -12 Sent 0 bytes 0 pkts (dropped 0, overlimits 0)
