Trigger a Layer 2 Tracetree
This procedure does not apply to XA1400 Series.
Use this procedure to trigger a Layer 2 tracetree. Layer 2 tracetree allows a user to trigger a multicast LTM message by specifying the B-VLAN and I-SID. The command allows the user to view a multicast tree on the SPBM B-VLAN from the source node to the destination nodes for a particular I-SID.
This command is supported on SPBM B-VLANs only, not C-VLANs.
                        On the source and destination nodes, you must configure a CFM MD, MA, and MEP.
                        Enable the MEP.
                        Assign a nodal MEP to the B-VLAN.
l2 tracetree {<1-4059> <1–16777215> [routernodename WORD<0–255> | <1-4059> <1–16777215>] [mac <0x00:0x00:0x00:0x00:0x00:0x00>}] [priority <0–7>] [source-mode <nodal|noVlanMac|smltVirtual>] [ttl—value <1–255>]
Switch:1#l2 tracetree 500 1 Switch:1# l2 tracetree 500 1 Please wait for l2tracetree to complete or press any key to abort l2tracetree to 53:55:10:00:00:01, vlan 500 i-sid 1 nickname 5.55.10 hops 64 1 Switch-PETER4 00:15:9b:11:33:df -> Switch-MONTI0 00:14:0d:a2:b3:df 2 Switch-MONTI0 00:14:0d:a2:b3:df -> Switch-LEE2 00:15:e8:b8:a3:df
The following table defines parameters for the l2 tracetree command.
| Variable | Value |
| { <1-4059><1–16777215> routernodename WORD<0–255> | <1-4059><1–16777215> mac <0x00:0x00:0x00:0x00:0x00:0x00>} |
| ttl-value <1–255> | Specifies the TTL value. The default is 64. |
| priority <0–7> | Specifies the priority value. The default is 7. |
| source-mode<nodal|noVlanMac|smltVirtual> | Specifies the source mode. The default is nodal. |
