View the members of all DvR domains namely the Controllers and Leaf nodes.
You can view this information on either a Controller or a Leaf node. Both the Controller and the Leaf node displays the members of the DvR domain to which it belongs.
Ensure that you enable DvR globally on the node.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select DVR.
  3. Select the Members tab.
  4. Optional: To filter the rows based on specific criteria, click Filter.
Members field descriptions
Use the data in the following table to use the Members tab.
Name
Description
MacAddress
Specifies the system ID or the nodal MAC address of this DvR member.
SysName
Specifies the system name of this DvR member.
NickName
Specifies the nick name of this DvR member.
Role
Specifies the DvR role (Controller or Leaf) of this DvR member.
DomainId
Specifies the domain ID of the DvR domain that this member belongs to.
