Table 1. Equal Cost Multiple Path for IPv6 product support
Feature
Product
Release introduced
ECMP for IPv6
5320 Series
Fabric Engine 8.6
Only 5320-48P-8XE and 5320-48T-8XE support more than one VRF with IP configuration.
5420 Series
VOSS 8.4
5520 Series
VOSS 8.2.5
5720 Series
Fabric Engine 8.7
7520 Series
Fabric Engine 8.10
7720 Series
Fabric Engine 8.10
VSP 4450 Series
VOSS 5.1
VSP 4900 Series
VOSS 8.1
VSP 7200 Series
VOSS 5.1
VSP 7400 Series
VOSS 8.0
VSP 8200 Series
VOSS 5.1
VSP 8400 Series
VOSS 5.1
VSP 8600 Series
VSP 8600 6.2
XA1400 Series
Not Supported
With Equal Cost Multipath (ECMP), the switch can determine equal-cost paths to the same destination prefix. You can use multiple paths for load sharing of traffic. These multiple paths allow faster convergence to other active paths in case of network failure. By maximizing load sharing among equal-cost paths, you can use your links between routers more efficiently when sending IP traffic. ECMP is formed using routes from the same source or protocol, and the ECMP routes are evaluated within each routing protocol.
The ECMP feature supports and complements the following protocols and route types:
