Display global information about flap-dampening.
  1. To enter User EXEC mode, log on to the switch.
  2. Display global information about flap-dampening:
    show ip bgp flap-damp-config [prefix/len] [vrf WORD<1–16>] [vrfids WORD<0–512>]
Switch(config)# show ip bgp flap-damp-config vrf vrf1
                        BGP Flap Dampening - VRF vrf1
                                           Status - enable
                                       PolicyName - N/A
                                  CutoffThreshold - 1536
                                   ReuseThreshold - 512
                                            Decay - 2
                                      MaxHoldDown - 180
The following table defines parameters for the show ip bgp flap-damp-config command.
Variable
Value
<prefix/len>
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32).
vrf WORD<1–16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids WORD<0–512>
Specifies a range of VRFs by ID number (the ID ranges from 0–512).
