Use the following procedure to display the MSDP peer information for a specific RP. The SA messages are received from the MSDP peer.
Switch:#enable Switch:1#show ip msdp rpf 172.16.10.13 ============================================================================ MSDP RPF - GlobalRouter =========================================================================== RPF peer information for (172.16.10.13) RPF peer: (172.16.121.10) RPF route/mask: 172.16.0.0/255.255.0.0 RPF rule: Peer is IGP next hop of best route RPF type: unicast (ospf)
Variable definitions
The following table defines parameters for the show ip msdp rpf command.
Variable |
Value |
{A.B.C.D} |
Specifies the RP IP address. |
vrf WORD<0–16> |
Displays configuration information for a particular VRF. |
vrfids WORD<0–512> |
Displays configuration information for a particular VRF ID. |
