Perform this procedure to configure Multi-area SPB Layer 3 static I-SID routed multicast redistribution policy in the remote area.
![Note](images/note.png)
Routed multicast redistribution is available for IPv4 only. With the MAC learning disabled, the static data I-SID multicast redistribution policy takes precedence over the Layer 2 multicast redistribution.
- In the navigation pane, expand the .
- Select MultiArea.
- Select the L3 MC Redist Remote Static ISID List tab.
- Select Insert.
- In the Type field, select staticisid.
- Select Enable.
- In the IsidListName field, type the name of the I-SID list.
- In the Apply field, select apply.
- Select Insert.
Use the data in the following table to use the L3 MC Redist Remote Static ISID List tab.
Name |
Descriptions |
Type |
Specifies the layer 3 static I-SID routed multicast redistribution type. The default type is staticisid. |
Enable |
Enables layer 3 static I-SID routed multicast redistribution in the remote area. The default value is disabled. |
IsidListName |
Specifies the name of the I-SID list. The default I-SID list name is htr. |
Apply |
Applies the Multi-area SPB layer 3 static I-SID routed multicast redistribution filters in the remote area. The default value is noAction. |
