Perform the following procedure to create and enable IPv6 IS-IS accept policies based on a particular Backbone Edge Bridge (BEB), I-SID, or I-SID list. IPv6 IS-IS accept policies filter incoming IS-IS routes that the device receives over the SPBM cloud. IPv6 IS-IS accept policies apply to incoming traffic and determine whether to add the route to the routing table.
IPv6 IS-IS accept policies are disabled by default.
  • IPv6 IS-IS accept policies are not supported for DvR.
  • The I-SID lists created can be associated with both IPv4 or IPv6 routes.
  • The ipv6 isis apply accept [vrf WORD<1-16>] command can disrupt traffic and cause temporary traffic loss. After you apply ipv6 isis apply accept [vrf <1-16>], the command reapplies the accept policies, which deletes all of the IS-IS routes, and adds the IS-IS routes again. You should make all the relevant accept policy changes, and then apply ipv6 isis apply accept [vrf WORD<1-16>] at the end.
  • If the route policy associated with an accept policy changes, you must reapply the IPv6 IS-IS accept policy, unless the IPv6 IS-IS accept policy was the last sequence in the configuration.
  • The ipv6 isis apply accept [vrf WORD<1-16>] command is not saved in the configuration file. If you use a saved configuration file for IPv6 IS-IS accept policy configuration, you must apply the ipv6 isis apply accept [vrf WORD<1-16>] command at the end.
    The number of unique Layer 3 VSN I-SIDs used on a BEB is limited to the number of VRFs supported on the switch. This includes the I-SID values used for Layer 3 VSNs and the I-SID values specified for the IPv6 IS-IS accept policy filters.
    The switch supports 24 VRFs by default, so, in a default configuration, you cannot create an I-SID list or accept policy with more than 24 unique I-SID entries. However, the configured VRFs take up an entry, so the formula to calculate the limit is: [24 VRF Limit – (currently configured VRFs)]. This gives the number of unique I-SIDs that can be used directly in the IPv6 IS-IS accept policy filters, which you implement with the ip isid-list or ipv6 accept command. The I-SIDs used for Layer 3 VSNs can be reused in IPv6 IS-IS accept policy filters without affecting the limit.
    If you increase the VRF scaling, you can create more Layer 3 VSNs. For more information about how to increase the number of supported VRFs, see Configure the Maximum Number of VRFs. The maximum number of supported VRFs and Layer 3 VSNs differs depending on the hardware platform. For more information about maximum scaling numbers, see VOSS Release Notes.
  • Enable IS-IS globally.
  • Ensure the manual area exists.
  • Configure IPv6 Shortcuts. For more information, see Configure SPBM IPv6 Shortcuts.
  • You must configure a route-map.
    enable
    configure terminal
  2. Optional: If you want to accept routes from a variety of I-SIDs, create an I-SID list before you create an IPv6 IS-IS accept policy for the I-SID list:
    ip isid-list WORD<1–32> {<1–16777215> | list WORD<1–1024>}
    When creating an I-SID list, you can add I-SID entries until the maximum limit for supported Layer 3 I-SIDs is reached. The system truncates any additional I-SID entries. The maximum limit includes the I-SIDs for locally configured Layer 3 VSNs and the I-SIDs specified for IS-IS accept policy filters.
    Use the command show ip isid-list vrf WORD<1-16> to view the list of truncated I-SIDs.
  3. Enter VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    router vrf WORD<1-16>
  4. Configure an IPv6 IS-IS accept policy instance with a route policy.
    Use one of the following options:
    1. Configure an IPv6 IS-IS accept policy based on a specific advertising BEB:
      ipv6 isis accept adv-rtr <x.xx.xx> [enable] [i-sid <0-16777215>] [isid-list WORD<1-32>] [ [route-map WORD<1–64>]
    2. Configure an IPv6 IS-IS accept policy based on a particular I-SID:
      ipv6 isis accept i-sid <0-16777215> [enable] [route-map WORD<1–64>]
    3. Configure an IPv6 IS-IS accept policy based on a particular I-SID list:
      ipv6 isis accept isid-list WORD<1-32> [enable] [route-map WORD<1–64>]
    4. Specify a particular route-map to use for all IS-IS routes from all BEBs unless a more specific filter exists for the advertising BEB. :
      ipv6 isis accept route-map WORD<1–64>
  5. Enable the configured IPv6 IS-IS accept policies:
    ipv6 isis accept [adv-rtr <x.xx.xx>] [i-sid <0-16777215>] [isid-list WORD<1-32>] enable
  6. Exit to Global Configuration mode:
    exit
  7. Apply the IPv6 IS-IS accept policy changes, which removes and re-adds all routes with updated filters:
    ipv6 isis apply accept [vrf WORD <1–16>]
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf vrftest
Switch:1(config-isis)#ipv6 isis accept i-sid 101 route-map test
Switch:1(config-isis)#ipv6 isis accept i-sid 101 enable
Switch:1#exit
Switch:1(config)#ipv6 isis apply accept
The following table defines parameters for the ip isid-list command.
Variable
Value
WORD<1-32>
Creates a name for your I-SID list.
<1-16777215>
Specifies an I-SID number.
list WORD<1-1024>
Specifies a list of I-SID values. For example, in the format 1,3,5,8-10.
The following table defines parameters for the ipv6 isis accept command.
Variable
Value
adv-rtr <x.xx.xx>
Specifies the SPBM nickname for each advertising BEB to allow you to apply the IPv6 IS-IS accept policy to routes for a specific advertising BEB. The system first uses the default filter, but if a more specific filter for a specific advertising BEB is present the device applies the specific filter.
Note:
An IPv6 IS-IS accept policy that specifies the adv-rtr without an I-SID or I-SID list will filter routes coming from the I-SID on which the policy is configured and from the specified BEB.
enable
Enables an IPv6 IS-IS accept policy.
i-sid <0-16777215>
Specifies an I-SID number to represent a local or remote Layer 3 VSN to which the IPv6 IS-IS accept policy applies.
Use the parameter to apply a filter for routes from specific I-SIDs that represent the remote VSN. Based on the routing policy the system applies, the system can redistribute the remote VSN to the VSN where you applied the filter.
An I-SID value of 0 represents the global routing table (GRT).
Specifies the I-SID list name that represents the local or remote Layer 3 VSNs to which the IPv6 IS-IS accept policy applies.
Use the parameter to apply a default filter for all routes from specific I-SIDs that represent the remote VSN. Based on the routing policy the system applies, the system redistributes the remote VSN to the VSN where you applied the filter.
Specifies a route policy by name.
You must configure the route policy earlier in a separate procedure.
The following table defines parameters for the ipv6 isis apply accept command.
Variable
Value
vrf WORD<1-16>
Specifies a VRF instance.
