Modify the egress QoS to DSCP mappings to change traffic priorities. As a best practice, use the default mappings.
Do not change the default values. If you change the values, make sure that the values are consistent on all other devices in the network. Inconsistent mapping of table values can result in unpredictable service levels.
  1. In the navigation tree, expand the following folders: Configuration > QOS.
  2. Click Mapping Tables.
  3. Click the Egress QoS To Dscp tab.
  4. Double-click the OutDscp file to change the value.
  5. Click Apply.
Egress QoS To Dscp field descriptions
Use the data in the following table to use the Egress QoS To Dscp tab.
Name
Description
QosLevel
Specifies the QoS level of the outgoing packet.
OutDscp
Specifies the equivalent value of the DiffServ code point (in decimal format).
OutDscpBinaryFormat
Specifies the equivalent value of the DiffServ code point (in binary format).
