View VRRP Information
Display VRRP port or VLAN information to verify your configuration. Show VRRP information by IPv6 address or virtual router ID. If you enter a virtual router ID or an IPv6 address when you view VRRP information, the information applies only to that virtual router ID or for that interface.
Switch:1>show ipv6 vrrp address ================================================================================ VRRP Info - GlobalRouter ================================================================================ VRID P/V IP MAC STATE CONTROL -------------------------------------------------------------------------------- 12 1/1 fe80:0:0:0:0:0:0:1234 00:00:5e:00:02:0c Init Disabled VRID P/V MASTER PRIO ADV UP TIME -------------------------------------------------------------------------------- 12 1/1 0:0:0:0:0:0:0:0 100 1 0 day(s), 00:00:00 VRID P/V CRITICAL IP CRITICAL IP ACCEPT ENABLED MODE -------------------------------------------------------------------------------- 12 1/1 0:0:0:0:0:0:0:0 No disable VRID P/V BACKUP BACKUP-MASTER FAST (ENABLED) ACTION HLD REM MASTER STATE ADV DWN -------------------------------------------------------------------------------- 12 1/1 disable down 400 (YES) none 30 0 VRID P/V GLOBAL ADDRESS -------------------------------------------------------------------------------- 12 1/1 1111::2222/64 Flags Legend: HLD DWN: Configured hold-down timer value, REM: REMaining hold-down timer value --More-- (q = quit)
Switch:1#show ipv6 vrrp interface verbose ========================================================================================== Vlan Vrrp for IPv6 Extended ========================================================================================== VLAN VRF VRRP MASTER ID NAME ID STATE CONTROL PRIORITY IPADDR ------------------------------------------------------------------------------------------ 40 GlobalRouter 1 init disable 100 0:0:0:0:0:0:0:0 40 GlobalRouter 2 init disable 100 0:0:0:0:0:0:0:0 All 2 Vlan Vrrp Extended Entries out of 18 Total Num of Vrrp displayed VLAN VRF VRRP HOLDDWN ACTION CRITICAL CRITICAL ID NAME ID TIME IP ENABLE IPADDR ------------------------------------------------------------------------------------------ 40 GlobalRouter 1 0 none disable 0:0:0:0:0:0:0:0 40 GlobalRouter 2 0 none disable 0:0:0:0:0:0:0:0 All 2 Vlan Vrrp Extended Entries out of 18 Total Num of Vrrp displayed VLAN VRF VRRP BACKUP BACKUP ADVERTISE FAST ADV FAST ADV MASTER ADV PREEMPT ID NAME ID MASTER MASTER INTERVAL INTERVAL ENABLE INTERVAL MODE STATE (s) (ms) (ms) --------------------------------------------------------------------------------------------- 40 GlobalRouter 1 disable down 1 200 disable 1000 enable 40 GlobalRouter 2 disable down 1 200 disable 1000 enable All 2 Vlan Vrrp Extended Entries out of 18 Total Num of Vrrp displayed ==================================================================================================== Port Vrrp for IPv6 Extended ==================================================================================================== PORT VRF VRRP MASTER NUM NAME ID STATE CONTROL PRIORITY IPADDR ---------------------------------------------------------------------------------------------------- 1/23 GlobalRouter 1 init disable 100 0:0:0:0:0:0:0:0 1/23 GlobalRouter 2 init disable 100 0:0:0:0:0:0:0:0 All 2 Port Vrrp Extended Entries out of 18 Total Num of Vrrp displayed PORT VRF VRRP HOLDDWN ACTION CRITICAL CRITICAL NUM NAME ID TIME IP ENABLE IPADDR ---------------------------------------------------------------------------------------------------- 1/23 GlobalRouter 1 0 none disable 0:0:0:0:0:0:0:0 1/23 GlobalRouter 2 0 none disable 0:0:0:0:0:0:0:0 All 2 Port Vrrp Extended Entries out of 18 Total Num of Vrrp displayed PORT VRF VRRP BACKUP BACKUP ADVERTISE FAST ADV FAST ADV MASTER ADV PREEMPT NUM NAME ID MASTER MASTER INTERVAL INTERVAL ENABLE INTERVAL MODE STATE (s) (ms) (ms) ---------------------------------------------------------------------------------------------------- 1/23 GlobalRouter 1 disable down 1 200 disable 1000 enable 1/23 GlobalRouter 2 disable down 1 200 disable 1000 enable All 2 Port Vrrp Extended Entries out of 18 Total Num of Vrrp displayed
Use the data in the following table to use the show ipv6 vrrp commands.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
link-local WORD<0–127> |
Displays information by link-local IPv6 address. |
verbose |
Displays extended information. |
vlan [<1-4059> ] |
vrid <1–255> |
Displays information by virtual router ID. |
vrf WORD<1–16> |
Specifies the VRF name. |
vrfids WORD<0–512> |
Specifies the VRF ID. |
