Configure the serial port devices to define connection settings for the console port. Depending on your hardware platform the console port displays as console or 10101.
Switch:1>enable Switch:1#config terminal Switch:1(config)#show boot config sio sio console baud 115200 1
The following table defines parameters for the boot config sio console command.
Variable |
Value |
baud <9600–115200> |
Configures the baud rate for the port from one of the following:
The default value differs depending on hardware platform:
