![Note](images/note.png)
This procedure does not apply to VSP 8600 Series or XA1400 Series.
You must configure a nickname for the specific SPBM instance on which you enable MSTP-Fabric Connect Multi Homing.
Configure the MSTP global version as mstp.
Perform this procedure to enable MSTP-Fabric Connect Multi Homing for a specific SPBM instance.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis Switch:1(config-isis)#spbm 1 stp-multi-homing enable
Variable definitions
The following table defines parameters for the spbm command.
Variable |
Value |
<1–100> |
Specifies the IS-IS SPBM instance ID to create an SPBM instance. |
stp-multi-homing enable |
Enables MSTP-Fabric Connect Multi Homing on the specific SPBM instance. The default is disabled. |
