The switch can query the number of ingress and egress IP multicast streams traversing the switch. After you configure the thresholds for ingress and egress records, if the record-usage goes beyond the threshold, the device notifies you by way of a trap on the console, logged message, or both.
If you do not configure the thresholds, the switch displays only the ingress and egress records currently in use.
Show the hardware resource usage:
Switch:1>show ip mroute hw-resource-usage
                       Multicast Hardware Resource Usage
EGRESS      INGRESS     EGRESS      INGRESS     LOG MSG   SEND TRAP  SEND TRAP
REC IN-USE  REC IN-USE  THRESHOLD   THRESHOLD   ONLY      ONLY       AND LOG
0           0           0           0           false     false      false
