Attaches or detaches a RA Guard policy on the specific interface.
Enter GigabitEthernet Interface
Configuration mode:
enable
configure
terminal
interface GigabitEthernet
{slot/port[/sub-port][-slot/port[/sub-port]][,...]}
If the platform supports channelization and the port is channelized, you must also
specify the sub-port in the format slot/port/sub-port.
Apply a RA Guard policy.
ipv6 fhs ra-guard
attach-policy WORD<1–64>
RA Guard device-role on the port has to be configured as 'router' before
attaching any RA Guard policy to the port. If device-role on the port is not 'router',
this command will fail with an appropriate error message.
Detach a RA Guard policy from an interface.
no ipv6 fhs
ra-guard attach-policy
OR
default ipv6 fhs
- Enable device role
verification attached to the port.
ipv6 fhs ra-guard device-role
{router|host} attach-policy WORD<1-64>
A DHCPv6 Guard policy can be attached to a port only if the device-role
configured on that port is 'server'.
