Configure route redistribution so that a VRF interface can announce routes that other protocols learn, for example, OSPF or BGP. Use a route policy to control the redistribution of routes. You can redistribute routes for the Global router (VRF 0) and within a user-defined VRF but not between different VRFs.
  • Ensure VRF instances exist.
  • Configure route policies, if required.
  • Change the VRF instance as required.
  1. In the navigation tree, expand the following folders: Configuration > IPv6.
  2. Click Policy.
  3. Click the Route Redistribution tab.
  4. Click Insert.
  5. Choose the protocol and route source.
  6. Select Enable.
  7. Choose the route policy to apply to the redistributed routes.
  8. Configure other parameters as required.
  9. Click Insert.
Route Redistribution Field Descriptions
Use the data in the following table to use the Route Redistribution tab.
Name
Description
DstVrfId
Specifies the destination VRF ID.
Protocol
Specifies the protocols for which you want to receive external routing information.
SrcVrfId
Specifies the source VRF ID.
RouteSource
Indicates if the protocol receives notification about the routes this source learns. The route source is equivalent to the owner in the routing table.
Enable
Enables or disables route redistribution. The default is disabled.
RoutePolicy
Specifies the route policies to apply to the redistributed routes from the source VRF. Use the route policy to determine whether the system advertises a specific route to the specified protocol.
Metric
Specifies the metric announced in advertisements. The default is 0.
MetricType
Specifies the metric type (applies to OSPF and BGP only). Specifies a type 1 or a type 2 metric. For metric type 1, the cost of the external routes is equal to the sum of all internal costs and the external cost. For metric type 2, the cost of the external routes is equal to the external cost alone. The default is type2.
