Remove All Secondary IP Interfaces From a VLANNEW!
Perform this procedure to remove all secondary IP addresses on a VLAN simultaneously.
To remove specific secondary IP addresses from a VLAN, use the no operator with the ip address {A.B.C.D} secondary command on the VLAN.
  1. Enter Privileged EXEC mode:
    enable
  2. Remove all Secondary IP Interfaces from a VLAN:
    clear secondary-ips vlan <1-4059>
