Use this procedure to enable Fabric Attach on an interface (port, static MLT or LACP MLT). Enabling FA on an MLT enables FA on all ports of the MLT. If your platform supports channelization, FA can also be enabled on channelized ports.
Verify that FA is enabled globally on the switch.
Enabling FA on a port or MLT is necessary for element discovery.
On the FA Server, FA is enabled globally by default. However, you must explicitly enable FA on the desired port or MLT interface. FA is successfully enabled on an MLT only if all ports of the MLT have FA successfully enabled. Enabling FA automatically configures LLDP on all ports. Tagging is configured and spanning tree is disabled.
Enable FA on a port:
Switch:1>en Switch:1#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/2 Switch:1(config-if)#fa enable Switch:1(config-if)#exit Switch:1(config)#
Enable FA on an MLT:
Switch:1>en Switch:1#conf t Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface mlt 10 Switch:1(config-mlt)#fa enable Switch:1(config-mlt)#exit Switch:1(config)#
Verify that FA is enabled on the interfaces.
When FA is enabled, message authentication is enabled by default. The authentication key is set to the default value and displays encrypted on the output.
Switch:1>show fa interface ===================================================================== Fabric Attach Interfaces ===================================================================== INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH ORIGIN STATUS ISID CVID STATUS KEY --------------------------------------------------------------------- Port2/10 enabled 0 0 enabled **** Port4/6 enabled 0 0 enabled **** Port4/11 enabled 0 0 enabled **** Mlt2 enabled 0 0 enabled **** --------------------------------------------------------------------- 4 out of 4 Total Num of fabric attach interfaces displayed ---------------------------------------------------------------------
For example, disable FA on port 1/1 and Mlt1.
Switch:1(config)#interface gigabitethernet 1/1 Switch:1(config-if)#no fa enable Switch:1(config-if)#exit Switch:1(config)#interface mlt 1 Switch:1(config-mlt)#no fa enable Switch:1(config-mlt)#exit
Verify that FA is disabled on port 1/1 and Mlt1.
Switch:1(config)#show fa interface =================================================================== Fabric Attach Interfaces =================================================================== INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH ORIGIN STATUS ISID CVID STATUS KEY ------------------------------------------------------------------- Port1/1 disabled 0 0 enabled **** Port1/2 enabled 0 0 enabled **** Mlt1 disabled 0 0 enabled **** Mlt10 enabled 0 0 enabled **** ------------------------------------------------------------------- 4 out of 4 Total Num of fabric attach interfaces displayed -------------------------------------------------------------------
View the FA interfaces that have authentication enabled:
Switch:1(config)#show fa interface enabled-auth ====================================================================== Fabric Attach Interfaces ====================================================================== INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH ORIGIN STATUS ISID CVID STATUS KEY ---------------------------------------------------------------------- Port1/2 enabled 0 0 enabled **** Mlt10 enabled 0 0 enabled **** ---------------------------------------------------------------------- 2 out of 2 Total Num of fabric attach interfaces displayed ----------------------------------------------------------------------
Optionally, disable FA message authentication on 1/1 and Mlt1.
Switch:1(config)#interface gigabitethernet 1/1 Switch:1(config-if)#no fa message-authentication Switch:1(config-if)#exit Switch:1(config)#interface mlt 1 Switch:1(config-mlt)#no fa message-authentication Switch:1(config-mlt)#exit
Verify that both FA and FA message authentication are disabled on 1/1 and Mlt1, as indicated by the SERVER STATUS and MSG AUTH STATUS fields respectively.
Switch:1(config)#show fa interface =================================================================== Fabric Attach Interfaces =================================================================== INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH ORIGIN STATUS ISID CVID STATUS KEY ------------------------------------------------------------------- Port1/1 disabled 0 0 disabled **** Port1/2 enabled 0 0 enabled **** Mlt1 disabled 0 0 disabled **** Mlt10 enabled 0 0 enabled **** ------------------------------------------------------------------- 4 out of 4 Total Num of fabric attach interfaces displayed -------------------------------------------------------------------
View the FA interfaces that have authentication disabled:
Switch:1(config)#show fa interface disabled-auth ======================================================================= Fabric Attach Interfaces ======================================================================= INTERFACE SERVER MGMT MGMT MSG AUTH MSG AUTH ORIGIN STATUS ISID CVID STATUS KEY ----------------------------------------------------------------------- Port1/1 disabled 0 0 disabled **** Mlt1 disabled 0 0 disabled **** ----------------------------------------------------------------------- 2 out of 2 Total Num of fabric attach interfaces displayed -----------------------------------------------------------------------
Variable definitions
The following table defines parameters for the show fa interface command.
Variable |
Value |
disabled-auth |
Displays the FA interfaces (port or MLT) that have authentication disabled. |
enabled-auth |
Displays the FA interfaces (port or MLT) that have authentication enabled. |
<1–512> |
The valid range for MLT ID. Displays FA configuration on the specified MLT interface. |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. Displays FA configuration on the specified port. |
