Perform this procedure to view MACsec status.
MACsec status
MACsec encryption status
MACsec encryption cipher suite, if supported on your hardware platform
The associated Connectivity Association (CA) name
If you do not specify a port number, the information on all MACsec capable interfaces is displayed.
enable
show macsec status {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
show macsec
The switch does not support replay protect.
View MACsec status:
Switch:1#show macsec status
MACSEC Port Status
MACSEC Encryption Replay Replay Encryption Cipher CA MKA-Profile MKA Connect
PortId Status Status Protect Protect W'dow Offset Suite Name Name Status
1/13 disabled disabled disabled -- none AES-128 NIL -- --
1/14 disabled disabled disabled -- none AES-128 NIL -- --
1/15 enabled disabled enabled 50 ipv4Offset(30) AES-256 mkanka extreme pending
View MACsec status on port 1/13:
Switch:1#show macsec status 1/13
MACSEC Port Status
1/13 enabled disabled enabled 50 ipv4Offset(30) AES-256 mkanka extreme pending
Display all MACsec information:
Switch:1>show macsec
MACSEC Connectivity Associations Info
Connectivity SHA-1 Connectivity AN_Mode / Port
Association Name Association Key Hash TxKeyParity Members
conn1 550e0fb1dec7eaa40a473b09790c8745 4AN / Even
All 1 out of 1 Total Num of Macsec connectivity associates displayed
MACSEC Port Status
1/1 disabled disabled disabled -- none AES-128 Nil -- --
1/2 disabled disabled disabled -- none AES-128 Nil -- --
1/3 disabled disabled disabled -- none AES-128 Nil -- --
1/4 disabled disabled disabled -- none AES-128 Nil -- --
1/5 disabled disabled disabled -- none AES-128 Nil -- --
