Perform this procedure to configure the area virtual node parameters like system name, system ID, and nickname on the remote Intermediate-to-Intermediate-System (IS-IS) instance.
  1. In the navigation pane, expand the Configuration > Fabric folders.
  2. Select IS-IS Remote.
  3. Select the Area VNode tab.
  4. Configure the parameters.
  5. Select Apply.
Area VNode Field Descriptions
Use the data in the following table to use the Area VNode tab.
Name Description
VNodeNickName
Specifies the nickname of the virtual node on remote IS-IS instance.
VNodeSysId
Specifies the system ID of the virtual node on remote IS-IS instance.
VNodeSysName
Specifies the system name of the virtual node on remote IS-IS instance.
