View information about the license file for the switch.
- Click Chassis.
- Click the License tab.
License field descriptions
Use the data in the following table to use the License tab.
Name |
Description |
FileName |
Indicates the file name of the current license. Note:
If this field is empty it indicates that there is no license installed on the switch. |
LicenseType |
Indicates the level type of the current license. |
DurationType |
Indicates the duration type of the current license. |
RemainingDays |
Indicates the days left before the factory default trial period or subscription license expires. Note:
For other license types, the field displays 0. |
GenerationTime |
Indicates the date on which the license file was generated. Note:
If there is no license installed on the system, this field displays 0000000000000000 H. |
ExpirationTime |
Indicates the date on which the license file expired. Note:
