Display key health information about the type of packets and protocols received on a port. This command helps debug high CPU utilization issues.
You can use the packets-per-second information in the output to identify where the bulk of packets destined for the CPU enter the switch.
Switch:1>show khi cpp port-statistics
         KHI CPP Details - Port Statistics
Port      Packet Type                           Rx Packets   Rx Diff    Rx Pps   Tx Packets   Tx Diff    Tx Pps
1653 seconds since issuing the last KHI command.
2/2       Ether2_LLDP(3)                                 0         0         0         2233         1         0
2/2       LLC_BPDU(128)                                  0         0         0        33508        10         0
2/2       LLC_TDP(134)                               11100         4         0        11090         4         0
2/3       Ether2_LLDP(3)                                 0         0         0         2233        56         0
2/3       LLC_BPDU(128)                                 16         0         0        33504       837         0
2/3       LLC_TDP(134)                               11100       278         0        11090       278         0
2/4       Ether2_LLDP(3)                                 0         0         0         2233        56         0
2/4       LLC_BPDU(128)                                  2         0         0        33508       837         0
2/4       LLC_TDP(134)                               11100       278         0        11090       278         0
Use the data in the following table to use the show khi cpp port-statistics command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). |
