SNMP Trap not Received
Perform the following procedure to troubleshoot issues in which an SNMP trap is not received.
    enable
    configure terminal
  2. Show the BPDU Guard status for the port:
    show spanning-tree bpduguard {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
  3. Configure the correct SNMP target information:
    snmp-server host WORD<1-256> [port <1-65535>] v3 {noAuthNoPriv|authNoPriv|authPriv WORD<1-32> [inform [timeout <1-2147483647>][retries <0-255>]] [filter WORD<1-32>]
In the following example, BPDU guard is enabled on port 1/8, BPDU packets are received, port 1/8 is disabled, and the TimerCount is incrementing, but no SNMP trap is ever received.
Switch:1>enable
Switch:1#show spanning-tree bpduguard 1/8
                                   Bpdu Guard
Port           PORT        PORT                 TIMER BPDUGUARD    BPDUGUARD
NUM      MLTID ADMIN_STATE OPER_STATE  TIMEOUT  COUNT ADMIN_STATE  ORIGIN
1/8            Down        Down        120      0     Disabled     CONFIG
The following table defines parameters for the show spanning-tree command.
Variable
Value
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
The following table defines parameters for the snmp-server host command.
Variable
Value
filter WORD<1-32>
Specifies a filter profile name.
host WORD<1-256>
Specifies the IPv4 or IPv6 host address
Specifies the notify type. The optional timeout parameter configures the timeout value, which specifies the time to wait for a reply before resending the inform message. Time is specified in centiseconds
Specifies the security level.
port <1-65535>
Specifies the port number that will be set as the destination port at the UDP level in the trap packet.
retries <0-255>
Specifies the number of packets to be sent if no reply is received.
