Display information about classless interdomain routing (CIDR) routes.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about CIDR routes:
    show ip bgp cidr-only [<prefix/len>] [vrf WORD<1–16>] [vrfids WORD<0–512>]
The following table defines parameters for the show ip bgp cidr-only command.
Variable
Value
<prefix/len>
Specifies an exact match of the prefix. This variable is an IP address and an integer value from 0–32 in the format a.b.c.d/xx.
vrf WORD<1–16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids WORD<0–512>
Specifies a range of VRFs by ID number (the ID ranges from 0–512).
