Use a protocol-based VLAN so that the VLAN only carries certain traffic types.
In the navigation tree, expand
the following folders: .
Select VLANs.
In the Basic tab, select
Insert.
In the Id box, type the
unique VLAN ID or use the ID provided.
In the Name box, type
the VLAN name or use the name provided.
In the Color Identifier
box, select the color or use the color provided.
This color is used to visually distinguish the VLANs in a network.
In the MstpInstance box,
select the down arrow and choose an MSTI instance from the list.
In the Type box, select
byProtocolId.
This activates additional fields needed to configure protocol-based
VLANs.
To specify the VLAN port
membership, select the button (...) for one of
the following fields:
Port
Members
OR
StaticMembers
OR
NotAllowToJoin
Select each port button to
choose the desired membership color.
Yellow: Potential members—dynamic (potential members are treated as always
members)
OR
Green: Always members—static
OR
Red: Never members—not allowed to join
![Important](images/important.png)
Important
In a protocol-based VLAN, a potential member becomes an active member of
the VLAN after a frame of the specified protocol is received.
Select Insert.
