If you downgrade to an earlier release that does not support this feature, you must disable the feature and save the configuration. Downgrading to an earlier release will require a compatible configuration file.
  1. Enter Logical IS-IS Interface Configuration mode:
    enable
    configure terminal
    logical-intf isis <1–255>
  2. Disable IPsec:
    no ipsec
  3. Disable IPsec compression:
    no ipsec compression
  4. Enable IPsec:
    ipsec
  5. Save the configuration.
  6. Verify the configuration:
    show isis logical-interface ipsec
Switch:1(config-isis-2-192.0.2.10)# no ipsec
Switch:1(config-isis-2-192.0.2.10)# no ipsec compression
Switch:1(config-isis-2-192.0.2.10)# ipsec
Switch:1(config-isis-2-192.0.2.10)#show isis logical-interface ipsec
                            ISIS Logical Interface IPSec
ID    Authentication-Key    Responder-Only    Remote NAT    IP Compression
2     ******                False             -             False
1 out of 2 Total Num of Logical ISIS interfaces
