This procedure only applies to VSP 8600 Series.
Perform this procedure to view information about the operating status of the power supplies.
- Select Power Supply Information.
Detail Field Descriptions
Use the data in the following table to use the Detail tab.
Name |
Description |
Id |
Specifies the ID number. This field is not supported on all hardware platforms. |
Type |
Describes the type of power used. |
Description |
Provides a description of the power supply. |
SerialNumber |
Specifies the power supply serial number. |
HardwareRevision |
Specifies the hardware revision number. |
PartNumber |
Specifies the power supply part number. |
PowerSupplyOperStatus |
Specifies the status of the power supply as one of the following:
InputLineVoltage |
Displays the input line voltage:
OutputWatts |
Displays the output power of this power supply. |
InputOperLineVoltage |
Displays the operating input line voltage. If the power supplies in a chassis are not of identical input line voltage values, the operating line voltage shows the low 110v value. This field is not supported on all hardware platforms. |
InputPower |
Displays the input power of this power supply. This field is not supported on all hardware platforms. |
FanFlowType Note:
Exception: only supported on VSP 7200 Series |
Displays the airflow direction of the power supply. |
