Configure I-SID Monitoring
Use the following procedure to configure Fabric RSPAN on the Backbone Edge Bridge (BEB) connected to the monitor station.
Do not configure the source of mirrored traffic (mirroring to an I-SID) and the analyzer (monitoring an I-SID) on the same local device with the same I-SID offset. If you require mirroring and monitoring on the same local device, use standard port-based mirroring instead of Fabric RSPAN. Fabric RSPAN mirrors traffic into an I-SID of the SPB Fabric network and monitors traffic on the remote device; the network analyzer resides on the remote monitoring device and not on the same local device.
If you change the egress port or egress MLT for a particular session using a CLI command, it overwrites the existing egress port list or egress MLT.
- Click General.
- Click the Monitor-By-ISID tab.
- Click Insert.
- Configure the parameters as required.
- Click Insert.
- To modify mappings, double-click a parameter to view a list of options.
- Click Apply.
Monitor-By-ISID Field Descriptions
Use the data in the following table to use the Monitor-By-ISID tab.
Name |
Description |
Index |
Specifies the entry that contains monitor by I-SID information. |
MonitorIsidOffset |
Configures the monitoring I-SID offset value. The offset ID is mapped to the actual monitor I-SID value to which the packets are mirrored. |
MonitorIsid |
Specifies the actual monitor I-SID value to which packets are mirrored. |
EgressPortList |
Specifies the egress ports to which traffic analyzers connect. |
EgressMltId |
Specifies the egress MLT ID to which traffic analyzers connect. |
MapToVlanId |
Specifies the VLAN ID to map with mirrored traffic on the monitoring node. |
Enable |
Enables or disables monitoring by I-SID. |
