View DvR domain redistribution information on a Controller or a Leaf node.
You can view DvR domain redistribution information only on a DvR Controller.
An error message displays if you attempt to view this information on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
View DvR domain redistribution information on a Controller:
Switch:1#show dvr redistribute =============================================================================================== DVR Redistribute List - GlobalRouter =============================================================================================== SOURCE MET MTYPE ENABLE RPOLICY ----------------------------------------------------------------------------------------------- STAT 1 External TRUE -
View DvR domain redistribution information for a particular VRF.
Switch:1#show dvr redistribute vrf vrf1 =============================================================================================== DVR Redistribute List - VRF vrf1 =============================================================================================== SOURCE MET MTYPE ENABLE RPOLICY ----------------------------------------------------------------------------------------------- STAT 20000 External TRUE - LOC 10000 Internal TRUE -
Variable definitions
Use the data in the following table to use the show dvr redistribute command.
Variable |
Definitions |
vrf WORD<1-16> |
Specifies the VRF name. |
vrfids WORD<0-512> |
Specifies the VRF ID of the VRF. |
