For certain switches in enhanced secure mode, all sensitive files are protected. The home directory for enhanced secure mode is /intflash/shared. You cannot access any sensitive files using Telnet, SSH, FTP, SFTP, TFTP, and SCP connections. For more information, see Sensitive File Protection.
The following table lists the access levels and file names you can use for storing the SSH client authentication information using RSA.
Table 1. RSA authentication access levels and file names
Client key format or WSM
Access level
File name
Client key in IETF format with enhanced secure mode disabled.
RWA
/flash/.ssh/rsa_key_rwa
RW
RO
/flash/.ssh/rsa_key_ro
L3
/flash/.ssh/rsa_key_rwl3
L2
/flash/.ssh/rsa_key_rwl2
L1
/flash/.ssh/rsa_key_rwl1
Client key with enhanced secure mode enabled
Note: Exception: does not apply to VSP 8600 Series.
administrator
/intflash/shared/rsa_key_admin
operator
/intflash/shared/rsa_key_operator
security
/intflash/shared/rsa_key_security
privilege
/intflash/shared/rsa_key_priv
auditor
/intflash/shared/rsa_key_auditor
Note: Exception: only applies to VSP 8600 Series.
administrator
/intflash/.ssh/rsa_key_admin
operator
/intflash/.ssh/rsa_key_operator
security
/intflash/.ssh/rsa_key_security
privilege
/intflash/.ssh/rsa_key_priv
auditor
/intflash/.ssh/rsa_key_auditor
administrator
