If you need to change the virtual IST PeerIp or VlanId, use this procedure to delete the vIST
first.
You must disable IS-IS globally before deleting a vIST, and then re-enable it
after creating a new vIST.
You do not have to set the SMLT peer system ID or the virtual B-MAC to 0
before you change the virtual IST peer IP address or VLAN ID number.
- Disable IS-IS globally.
In the navigation pane,
expand the following folders: .
Select the Globals
tab.
In the AdminState field, select off.
Select Apply.
- Delete the
vIST.
- In the navigation pane, expand the following folders: .
Select the Virtual
IST tab.
Select Apply.
- Create a
vIST:
Select the Virtual IST tab.
- In the PeerIp field,
enter the peer IP address.
- In the VlanId field,
enter a VLAN ID.
Select Apply.
- Enable IS-IS globally.
Select the Globals
tab.
In the AdminState field, select on.
Select Apply.
