Use this procedure to view IPsec statistics and counter values at the switch level for all IPsec-enabled interfaces.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click IPSec.
  3. Click the Global Stats tab.
Global Stats Field Descriptions
Use the data in the following table to use the Global Stats tab.
Name
Description
InSuccesses
Specifies the number of ingress packets IPsec successfully carries.
InSPViolations
Specifies the number of ingress packets IPsec discards since boot time because of a security policy violation.
InNotEnoughMemories
Specifies the number of ingress packets IPsec discards since boot time because not enough memory is available.
InAHESPReplays
Specifies the number of ingress packets IPsec discards since boot time because the AH replay check fails.
InESPReplays
Specifies the number of ingress packets IPsec discards since boot time because the ESP replay check fails.
InAHFailures
Specifies the number of ingress packets IPsec discards since boot time because the AH authentication check fails.
InESPFailures
Specifies the number of ingress packets IPsec discards since boot time because the ESP authentication check fails.
OutSuccesses
Specifies the number of egress packets IPsec successfully carries since boot time.
OutSPViolations
Specifies the number of egress packets IPsec discards since boot time because a security policy violation occurs.
OutNotEnoughMemories
Specifies the number of egress packets IPsec discards since boot time because not enough memory is available since boot time.
generalError
Specifies a general error.
InAHSuccesses
Specifies the number of ingress packets IPsec carries because the AH authentication succeeds.
OutAHSuccesses
InESPSuccesses
Specifies the number of ingress packets IPsec carries since boot time because the ESP authentication succeeds.
OutESPSuccesses
OutKBytes
Specifies the total number of kilobytes on egress.
OutBytes
Specifies the total number of bytes on egress.
InKBytes
Specifies the total number of bytes on ingress.
InBytes
TotalPacketsProcessed
Specifies the total number of packets processed.
TotalPacketsByPassed
Specifies the total number of packets bypassed.
OutAHFailures
Specifies the number of egress packets IPsec discards since boot time because the AH authentication check fails.
OutESPFailures
Specifies the number of egress packets IPsec discards since boot time because the ESP authentication check fails.
InMD5Hmacs
Specifies the number of inbound HMAC MD5 occurrences since boot time.
InSHA1Hmacs
Specifies the number of inbound HMAC SHA1 occurrences since boot time.
InAESXCBCs
Specifies the number of inbound AES XCBC MAC occurrences since boot time.
InAnyNullAuth
Specifies the number of inbound null authentication occurrences since boot time.
In3DESCBCs
Specifies the number of inbound 3DES CBC occurrences since boot time.
InAESCBCs
Specifies the number of inbound AES CBC occurrences since boot time.
InAESCTRs
Specifies the number of inbound AES CTR occurrences since boot time.
InAnyNulEncrypt
Specifies the number of inbound null occurrences since boot time. Used for debugging purposes.
OutMD5Hmacs
Specifies the number of outbound HMAC MD5 occurrences since boot time.
OutSHA1Hmacs
Specifies the number of outbound HMAC SHA1 occurrences since boot time.
OutAESXCBCs
Specifies the number of outbound AES XCBC MAC occurrences since boot time.
OutInAnyNullAuth
Specifies the number of outbound null authentication occurrences since boot time.
Out3DESCBCs
Specifies the number of outbound 3DES CBC occurrences since boot time.
OutAESCBCs
Specifies the number of outbound AES CBC occurrences since boot time.
OutAESCTRs
Specifies the number of outbound AES CTR occurrences since boot time.
OutInAnyNullEncrypt
Specifies the number of outbound null occurrences since boot time. Used for debugging purposes.
