This section describes how to configure the Network Time Protocol (NTP) using EDM.
Before you configure NTPv4, you must create a Segmented Management Instance and configure routing for that instance.
Important
NTP server MD5 authentication or SHA1 authentication does not support passwords (keys) that start with a special character or that contain a space between characters.
