This procedure does not apply to VSP 8600 Series.About this task
View virtual links in the link-state database.
- Select OSPF.
- Select the Virt Local Lsdb tab.
Virt Local Lsdb Field Descriptions
Use the data in the following table to use the Virt Local Lsdb tab.
Name |
Description |
TransitArea |
Specifies the ID for the transit area that the virtual link traverses. |
Neighbor |
Specifies the router ID of the of the virtual neighbor. |
Type |
Specifies the type of the link-state advertisement. |
Lsid |
Specifies the piece of the routing domain that the advertisement describes. |
RouterId |
Specifies the originating router in the Autonomous System. |
Sequence |
Specifies old and duplicate link-state advertisements. |
Age |
Specifies the age, in seconds, of the link-state advertisement. |
Checksum |
Contains the checksum of the complete contents of the advertisement, except for the age parameter. The checksum does not include the age parameter so that advertisement age increments without updating the checksum. |
Advertisement |
Specifies the size of the entire link-state advertisement. |
