Showing Extended VLAN VRRP
Perform this procedure to display the extended VRRP configuration for all VLANs or a specified VLAN on the device.
Switch:1>show ip vrrp interface vlan
Vlan Vrrp
VLAN VRF VRRP IP VIRTUAL VERSION ORIGIN
ID NAME ID ADDRESS MAC ADDRESS
2 GlobalRouter 10 203.0.113.2 00:00:5e:00:01:0a 2 config
222 GlobalRouter 1 192.0.2.1 00:00:5e:00:01:01 2 config
223 GlobalRouter 1 198.51.100.1 00:00:5e:00:01:01 3 config
The following table defines parameters for the show ip vrrp interface vlan command.
Variable |
Value |
<1-4059> |
portList |
Specifies the slot or port number of a range of ports. |
vrf WORD<1-16> |
Specifies the name of the VRF. |
vrfids WORD<0-512> |
Specifies the ID of the VRF and is an integer in the range of 0–512. |
Use the data in the following table to use the show ip vrrp interface vlan command output with the optional verbose parameter.
Variable |
Value |
VLAN ID |
Indicates the VLAN ID. |
VRRP ID |
Indicates the virtual router ID. |
VRF NAME |
Indicates the associated VRF name, if applicable. |
STATE |
Indicates the current state of the virtual router.
CONTROL |
Indicates the virtual router function. Configure the value to enabled to transition the state of the router from initialize to backup. Configure the value to disabled to transition the router from master or backup to initialize. |
PRIORITY |
Indicates the priority for the virtual router (for example, master election) with respect to other virtual routers that are backing up one or more associated IP addresses. Higher values indicate higher priority. A priority of 0, which you cannot configure, indicates that this router ceased to participate in VRRP and a backup virtual router transitions to become a new master. Use a priority of 255 for the router that owns the associated IP addresses. |
MASTER IPADDR |
Indicates the master router real (primary) IP address. The master IP address is listed as the source in the VRRP advertisement last received by this virtual router. |
ADVERTISE INTERVAL |
Indicates the time interval, in seconds, between sending advertisement messages. Only the master router sends VRRP advertisements. |
CRITICAL IPADDR |
Indicates the IP address of the interface that causes a shutdown event. |
VERSION |
Indicates the VRRP version. |
HOSTNAME Note:
Exception: not supported on VSP 4450 Series, VSP 8600 Series, or XA1400 Series. |
Displays the SPBM host name of the VRRP primary router for a Distributed Virtual Routing (DvR) interface. |
ORIGIN Note:
Displays how the VRRP interface was configured, either manually or via DvR. |
HOLDDOWN_TIME |
Indicates the configured time (in seconds) that the system waits before it preempts the current VRRP master. |
ACTION |
Indicates the trigger for an action on this VRRP interface. Options include none and preemptHoldDownTimer. |
CRITICAL IP ENABLE |
Indicates that a user-defined critical IP address is enabled. No indicates the use of the default IP address (0.0.0.0). |
BACKUP MASTER |
Indicates the state of designating a backup master router. |
BACKUP MASTER STATE |
Indicates the state of the backup master router. |
FAST ADV INTERVAL |
Indicates the time interval, in milliseconds, between sending Fast Advertisement messages. When the Fast Advertisement Interval is enabled, the Fast Advertisement Interval is used instead of the regular advertisement interval. |
FAST ADV ENABLE |
Indicates the Fast Advertisement Interval status. |
MASTER ADV INTERVAL (ms) |
On the VRRPv3 master, the master advertisement interval is same as the advertisement interval. On the VRRPv3 Backup, the master advertisement interval is set to the Advertisement configured on the Master (received in the packet). |
PREEMPT MODE |
Indicates if the router operates in preempt mode. If a new router is added to the network with its priority higher than the existing routers, then the new router becomes the master. |
PSEUDO-HEADER CHECKSUM |
Specifies the type of checksum computation, with Pseudo Header or without Pseudo Header. |
