You can use this interface type for OOB management network routing, as an alternative to in-band network routing management.
The OOB Segmented Management Instance is not supported on VSP 4450 Series or XA1400 Series.
The following list defines the abilities of this interface type:
You can assign a management IP address bound to the Out-of-Band (OOB) interface.
You can associate only one OOB interface with an OOB Management Instance IP address.
You can use a VLAN IP address including primary and secondary IP address on a local VLAN.
The Dynamic Host Configuration Protocol (DHCP) Client can request an IPv4 address for the OOB Management Instance interface.
You must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure only Layer 3 networking parameters in the Management Instance Configuration mode (mgmt OOB) in CLI.
You can configure only Layer 1 and Layer 2 networking parameters in the mgmtEthernet Interface Configuration mode (interface mgmtEthernet mgmt) in CLI.
