Display DHCP-relay statistics for all interfaces to manage network performance.
Slot and port information can differ depending on hardware platform.
Switch:1>show ip dhcp-relay counters option82 =============================================================================================== DHCP Counters Option82 - GlobalRouter =============================================================================================== IP FOUND DROP CIRC ADD DEL REMOTE ADD DEL INTERFACE ADDR OP82 PKT ID CIRC CIRC ID REMID REMID ----------------------------------------------------------------------------------------------- Port 1/12 0 0 395 0 0 00:24:7f:9d:0a:00 0 0 Vlan40 0 0 2088 0 0 00:24:7f:9d:0a:01 0 0
Use the data in the following table to use the show ip dhcp-relay counters command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF instance by the VRF name. |
vrfids WORD<0-512> |
Specifies the ID of the VRF. |
