Trigger a Loopback Test
Use this procedure to trigger a loopback test.
The LBM packet is often compared to ping. An MEP transmits the loopback message to an intermediate or endpoint within a domain for the purpose of fault verification. This can be used to check the ability of the network to forward different sized frames.
- On the source and destination nodes, you must configure a CFM MD, MA, and MEP.
- Enable the MEP.
- Assign a nodal MEP to the B-VLAN.
- Click CFM.
- Click the LBM tab.
- Configure the loopback test properties as required.
- Click Apply.
- To trigger the loopback test, double-click in the Status field, select transmit.
- Click Apply.
- To update the loopback test, click the Refresh button.
LBM Field Descriptions
Use the data in the following table to use the LBM tab.
| Name | Description |
| DomainIndex | Specifies the MD index value. |
| AssociationIndex | Specifies the MA index value. |
| Index | Specifies the Maintenance Endpoint index value. |
| DomainName | Specifies the MD name. |
| AssociationName | Specifies the MA name. |
| DestMacAddress | Specifies the remote MAC address to reach the MEP/MIP. |
| Messages | Specifies the number of loopback messages to be transmitted. The default is 1. |
| VlanPriority | Specifies the priority. The default is 7. |
| SeqNumber | Specifies the transaction identifier/sequence number of the first loopback message (to be) sent. The default is 0. |
| ResultOk | Indicates the result of the operation:
 The default is true. |
| Status | Indicates the status of the transmit loopback service:
 The default is ready. |
| Result | Displays the LBM result. |
| TimeoutInt | Specifies the timeout interval in seconds. The default value is 3 seconds. |
| InterFrameInt | Specifies the interval between LBM frames with a range of (0..1000) msecs and a default value of 500 msecs. The value of 0 msecs indicates to send the frames as fast as possible. The default is 500. |
| TestPattern | Specifies the testfill pattern:
 A cyclic redundancy check is a code that detects errors. The default value is allZero. |
| DataSize | Specifies the data type-length-value (TLV) size. The default is 0. |
| FrameSize | Specifies the frame-size. The default is 0. |
| Sourcemode | Specifies the source mode of the transmit loopback service:
 The default is nodal. |
