Configure a Remote VTEP
Exception: only supported on VSP 7200 Series, VSP 7400 Series, VSP 8200 Series, and VSP 8400 Series.
Use the following procedure to configure the remote VTEP destination. The total number of VTEP remote destination IPs that you can configure is 500.
- Select VTEP.
- Select the Vtep tab.
- In the Id field, assign a unique index value to this remote VTEP.
- In the IpAddr field, enter the IP address of this remote VTEP.
- In the Name field, assign a name to this remote VTEP.
- Select Apply.
Vtep field descriptions
Use the data in the following table to use the Vtep tab.
Name |
Description |
Id |
Specifies an index value in the range from 1 to 500 that uniquely identifies this remote VTEP. |
IpAddr |
Specifies an IP address that uniquely identifies this remote VTEP. Note:
The remote VTEP IP address cannot be a local, broadcast, or multicast IP address. |
Name |
Assigns a name to this remote VTEP tunnel. |
NextHopVrfName |
Displays the VRF name of the next hop to reach the remote VTEP. |
OvsdbConfigured |
Specifies if the VTEP is configured with OVSDB protocol support for VXLAN Gateway. |
