Use this procedure to filter on specific Ethernet source addresses.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation tree, expand the following folders: Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select Eth.
  8. Select the Source Address tab.
  9. Select Insert.
  10. Specify the ACE Ethernet operation.
  11. In the List dialog box, specify the Ethernet source address.
  12. Select Insert.
Source Address Field Descriptions
Use the data in the following table to use the Source Address tab.
Variable
Value
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.
List
Specifies the MAC address to match.
OperMask
Specifies the MAC Address mask value in hexadecimal format. The value for this variable is empty or 000000000000 if the Oper variable is eq.
