Perform this procedure to add location information of local LLDP-MED configured on specific ports.
- Click Port MED.
- Click the Local Location tab.
- In LocationInfo column, double-click on the cell, and type the information.
Local Location Field Descriptions
Name |
Description |
PortNum |
Specifies the port number. |
LocationSubtype |
Specifies the location subtype of the local LLDP-MED:
LocationInfo |
Specifies the location information of local LLDP-MED. The parsing of this information depends on the location subtype. |
