Display information about BGPv6 imported routes.
  1. To enter User EXEC mode, log on to the switch.
  2. Display information about BGPv6 imported routes:
    show bgp ipv6 imported-routes [<prefix/len>] [longer-prefixes] [vrf WORD<1–16>] [vrfids WORD<0–255>]
The following table defines parameters for the show bgp ipv6 imported-routes command.
Variable
Value
longer-prefixes
Shows long prefixes. The longer-prefixes indicate the mask length from a specified prefix to 32 (for example, show from prefix a.b.c.d/len to a.b.c./32).
<prefix/len>
Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32).
vrf WORD<1–16>
Specifies a VRF instance by name (the string length ranges from 1–16 characters).
vrfids WORD<0–255>
Specifies a range of VRFs by ID number (the ID ranges from 0–255).
